Non Standard Shifting and Brake cables.
Chandrider
Regular
India
I had racer bike but had to move the handle bar up by 3 inches due to neck problems.. I have Shimano Ultegra set. Now I need to adjust brake and shifter - all four cables. The standard set available are with fixed outer length.. Any suggestion how can i buy free length, cut to size and use?
ianrauk
Tattooed Beat Messiah
Rides Ti2
Try your LBS. They usually have cable outers on a large roll of which they cut to length.
keithmac
You get the little end caps that go over the outer after you've cut it to length.
Good quality sharp sidecutters are a must to make a clean cut.
Tim Hall
Crawley
I'd favour a pair of bike specific cable cutters, ones where the blades overlap like scissors rather than side cutters where the blades butt together. But if those work for you, keep on going.
