Incontinentia Buttocks
Apologies if I have put this on the wrong section, Admin, please move to the correct one if I have.
Anyway, numb toes. Not from the cold, but from cycling. I have a pair of old Shimano RO76 shoes with R540 SPD-SL pedals, and after about 30mins my toes begin to go numb on both feet from the ball forward. If I stop and take my foot out of the clip the feeling comes back, start pedalling again and it comes back, this is quite an issue.
I have tried moving the cleats forwards backwards sides, every which way, I've tried the shoes loose and tight, I've even got a Specialized Insole, but nothing seems to do the trick.
I've booked in at BikeDynamics to get myself and my new bike fitted together properly and I'm hoping with the cleat fittings Mike will be able to sort me out.
The Shoes seem to be the correct size and I can vaguely remember having the same problems with my Dads Peugeot many years ago when using the toe clips.
Has anybody else suffered the same? any ideas that I should try?
Thanks for reading
Chris
Thanks for reading
Chris
Didn't feckin work, basically when you walk you put you're foot forward first you put toe's down then as you move forward and then transfer to the ball , but when your sitting on your bike you are not articulating your foot you are in one position, so position your cleat in the position on your shoe where you put the most pressure on your foot when pushing forward when you walk,,,try it if it doesn't work for you try something else.... we are not al lthe same, that would be F**cking boring....
