Denis99
- South Wales
I have had the NuVinci IGH for about a year now, ridden about 2,000 miles on it with no problems.
It has been fitted to my Trek Super Commuter 9+ ebike.
Took a bit of a plunge into this hub system, as there is the same model of ebike with convention derailleur gears.
Apart from rotating the chain at 1,000 miles ( I always use two chains to minimise any wear),and the occasional chain tensioning, the system has worked flawlessly.
It is very nice to simply micro adjust the gearing, as opposed to the bigger incremental gear change of other gear systems.
Easy to keep clean simple chain line, cheap chains.
Definitely more drag than say a Rohloff system, and quite a bit heavy.
Suits an ebike really well.
Any other NuVinci hub experiences?
