Hi,
I bought a new bike for my son. He reported I don’t think the front brakes are quite working right.
I dutifully inspected them and found the following:
1. If I brake harshly (eg quickly and with force as if emergency stopping) then the brake lever moves a little and stays in position until released (as expected) and the brakes work as expected. For me this rules out air in the system as the brakes would feel spongy and not be working tremendously well.
2. If I brake gently as if gently coasting to a halt over a few hundred metres then something alarming happens. As you are gently applying constant pressure to the brake lever it slowly moves back until it touches the handlebar when you then run out of travel and hence brakes. A quick release of the brakes recharges the system and you can begin the whole process again.
3. There is no visible evidence of brake fluid leaking at the bars, the hoses or the callipers.
The bike was returned to a store owned by the seller who bled the system 4 times, did not find air in the system and confirmed the fault was still present. This did not surprise me as under hard braking the lever is firm so I did not expect to find air in the system,
The bike was returned to the factory where they have bled the system and are reporting system OK.
My thoughts.
If there was air in the system it would affect braking whether gentle or hard. I do not believe air in the system can explain harsh braking being OK and gentle braking meaning the brake lever moves to the handlebar.
I cannot think of a condition where brake fluid itself can cause the issue, it does not compress more under gentle load than hard load!
My thoughts are there is a seal somewhere that is damaged or mis formed. Under hard pressure the pressure of the fluid is splaying the seal sufficiently to create a seal and the brakes feel normal. Under low pressure the seal is not splayed and the brake fluid can creep past the seal. When the brake is released there is a return path for the brake fluid to recharge the system.
So what I am asking is do the above conclusions sound sensible and has anyone come across this type of failure before?
Braking system is Shimano 105.
Thanks all,
Mark
My thoughts.
Thanks all,
Mark
