BigonaBianchi
Yes I can, Yes I am, Yes I did...Repeat.
- Iskele TRNC & Mordor UK
I just had my third puncture in a week, it's not much fun anymore. I have continental 23 tyres on there because they were fitted on the bike when I bought it. I am looking to get some stronger tyres as per previous thread. BUT I just put all three tubes under water and found the bubbles and all of the holes are on the inside of the tube (same side as the valve). That tells me the problem is internal not external. so I took a look inside the wheel and dont see any thing obvious, I feel dont feel anything either when I run my fingers gently round the inside of the rim.. (g
d that sounds bad sorry
).....I dont get it..what could be doing this? Both front and rear wheels are affected. I pump the tyres up to max 120psi as per the tyre wall max...I ride on normal rodes and avoid bumps potholes etc...
...I dont want to spend out money on expensive tyres if the tyres arnt actually the problem.
Thanks for any help.
