Old EE router.
Milzy
I found my old EE router in a draw. I decided to Ethernet it up as an extender even though EE say don’t do this.
It works amazing. So many more mbps coming out than the plug in Netgear extender. The only problem is the light flashes instead of being solid. I’ve done a hard reset. The Admin password no longer works so I can’t get in to fiddle with any settings. I’ve tried the QR code. No longer works. EE must have blocked it, I can’t think of any other reason. Anyway the garage will get more speed for Zwift. The flashing light could just be because it’s old hardware.
Drago
The Urban Fringe
Just stick a piece of tape over the light.
Milzy
Milzy
It sometimes confuses the main router so I’ve put the Netgear extender back in. You live & learn.
Alex H
Alnwick
Can't you just reset it to factory default to change the password?
Milzy
Milzy
I couldn’t seem to. After re-set the old password should be the one. Anyway it was good for so long until my IPTV started playing up due to conflict. That’s what EE said you’ll risk. So back to old rubbish net gear plug in.
Milzy
Milzy
I’ve realised why the admin pass maybe wouldn’t work. It was Ethernet-connected to the main router. If I plugged it in as primary I could get in to turn off dhcp.
