philepo
Hello
I have bought a fairly well used Brompton from Ebay: a 5 speeder (I really wanted the gears and don't like the 6 speed Heath Robinson setup). I know, £1100 for a new one probably is better value than £500 for a 18 year old one, but if you don;t have £1100 and think the new gears are daft then....
So, I thought that the headstock/stem neck area was flexing a little too much especially when pulling back on the bars, but actually (I filmed the bike side on and could see it) it is bendy at the main frame hinge clamp. Now, is this: hinge pin worn? alloy clamp worn? Not tightening? Tube either side bending? Corrosion or fatigue weakened tubing? Though I was worried that I'd bought one with a frame about to snap, it turns out that the hinge itself does not mate together well and there is a bit of play in the hinge pin. Now, is that hinge pin play important? Well the handlebar stem hinge also has a similar amount of play in it but that hinge clamps up solidly and there is no play once tightened. So I think the main issue is the clamping side of the hinge, not the pin; the face plates of the mating surface that the alloy clamp plate is supposed to compress together is not fully flat or parallel meaning that the hinge has a small gap (I can see a torch light through it). This is the source of the bendy flex when I pull on the handlebars. it is essentially clamped at one single point on the clamp side and retained by a hige with play in it on the other, hence feels bendy (actually I suppose this is just loose play but feels bendy).
Finally(!) my question is is this normal on an older model / has anyone else sorted this? I was thinking: Engineers blue, clamp up, see where high low spots are, file until a good clamping mating surface is achieved and try not to ruin frame in my cackhandedness. or is this something a bike shop could do / has it been seen on here before???? Any comments ideas welcome (apart from buy a new one
Cheers all
)Cheers all
I from an engineering pov don;t like it. Besides, even though I test rode one and could use the gears just fine, when I came to a busy roundabout I found that if I didn;t know whether I was in 4th or 5th gears, for example, it was very hard to shift then as you have to know
