Oomph coffee maker
I've been thinking about one also. Similar to the aeropress
KneesUp
Similar, buy way more complicated and presumably more expensive, fiddler and harder to clean?
"The Oomph is the only pressure brewer on the market capable of varying the strength and flavour of your coffee after the brewing process ..."
Or, alternatively, just brew it correctly?
Levo-Lon
So you want a coffee machine so you can have a coffee break when you get your new drill...i don't know your sounding more like a plumber every day:laugh:
Tim Hall
Crawley
Looks like a solution looking for a problem. A cafetiere or Aeropress would be just as quick, less likely to break and a lot less fiddly to clean.
I get better results (nicer tasting coffee) from my Aeropress, but use a combined cafetiere/mug at work. Available at Lakeland.
OK, I found Mathew, the inventor, explaining how to make an Ooomph, what you and I call, coffee. It looks farking shite and for that reason..........I'm out.....but good luck Mathew.
I'm off now to press a button and make a proper coffee without the need for any Ooomph.
got one and use it at work find it easy to use and clean.
Pale Rider
But it's got Intelligent Grind Correction, so it must be good.
Good God! What the hell is that. As far as I could see from the demo, which took 3 damn minutes, it doesn't do any grinding and I'm not going back to the website to find out. There's probably another three minute video on how to clean it and another on how to store it, all buried deep within the marketingbabble.
i use ground coffee and then take apart rinse and clean not too much 'Faff really and use it at work so being paid to do it as well result !!!!!
KneesUp
There's probably another three minute video on how to clean it and another on how to store it,.
I'd suggest it goes at the back of the cupbaord of doom, with the Geroge Formeman grill and the chocolate fountain someone bought you for Christmas once.
