Optical Audio Cables
raleighnut
So the cables have got longer!!! ^_^
They started off at 5m, see my earlier post,
Decent speaker cable need not be expensive, I use 4x5m lengths of QED 96 strand (bi-amped set up).....................total cost £20 but every year I cut off the bared section and strip 1/2" of outer and reconnect.
Profpointy
Someone made the point that if the exotic cables do really sound different from ordinary cables, then it's likely they (the posh cables) are actually changing the signal in some way and hence not hi-fi. eg extra capacitance, inductance / strange frequency filtering etc.
I had a demo once of a very very expensive system (£60k for the amps alone - just to be clear I'd bought a minor item and the demo was merely a bit of fun) . The guy was ernestly explaining that the speakers had a frequency response up to 60kHz and somehow that helped the audible effect on the lower frequencies - even though you can't hear that high, and even if you could, there are no signals that high on the recording in the first place. Total BS though the guy earnestly believed this
Were they carrying analogue or digital data?
Profpointy
Analogue. I think even the most gullible here agrees that digital signals are unaffected by cables (unless faulty)
marknotgeorge
Hol den Vorschlaghammer!
Derby.
[QUOTE 4568282, member: 45"]Apparently for optimum results you should soak the cables in vinegar and then bake them.
Wait....sorry, that's conkers.[/QUOTE]
I heard you had to coat them in batter, then fry them. No wait, that's bollocks.
marknotgeorge
Derby.
You've used this GIF a few times to outline your point. You do realise that Jay is as thick as pigpoo and in all likelyhood permanently stoned, don't you?
ColinJ
Puzzle game procrastinator!
Or badly designed ... :whistle:
I remember working on a system with an unreliable digital control connection between 2 racks of equipment. The cable and connectors were in good condition, but the connection was prone to picking up interference which crashed the system several times a day. In the end the problem was solved by upgrading to a twisted-pair cable and differential drivers/receivers. Before the change the office kettle switching off 20 feet away would cause failure. After the robust communication system replaced the dodgy one we could never get it to fail again!
ColinJ
[QUOTE 4570392, member: 259"]Long ago in a previous life, I went to the Baghdad stock exchange and had a nice cup of tea from a pan of water that was kept nice and hot by sitting it on the cooling grille of one of their main server racks.[/QUOTE]
I'm sure I read somewhere that the power needs of the growing number of huge buildings full of web servers are a very significant proportion of global energy consumption!
Doseone
Brecon
Some analogue cables do make a difference (copper v silver & solid v stranded core).
Digital cables are all the same, Garbage In, Garbage Out.
Read some of the questions & reviews on this cable here if you want some light relief..
https://www.amazon.com/AudioQuest-Diamond-6-56-Braided-Cable/dp/B003CT2A2M
Brilliant:laugh:
949 of 1,013 people found the following review helpful
2.0 out of 5 stars Good cable, terrible instructions 13 Jan. 2013
By Patrick E. Hansen - Published on Amazon.com
I love this cable. Crystal clear audio and video. My only problem was that the instruction manual was very vague and misguiding. Long story short, I got it stuck in my urethra.
