Night Train
Maker of Things
- Greater Manchester
I have uPVC tilt and turn windows that open inwards.
One of them is very draughty (actually none are great and fitted by 'Bodge it and Scarper') and I have tracked it down to the side of the opener, where the handle is, not compressing the seal. If I lean heavily on the handle then the window seals up nicely.
As it is a tilt and turn there are only catches in the corners and not on the long edges of the opener, so nothing I can adjust to make it pull in tighter.
The corners, where the catches are, are already tight.
It is the opener that is slightly bowed inwards, about 3-4mm over the 900mm height.*
Is there any simple or easy fix to reverse the bow in the plastic?
I have thought about removing and dismantling the opener, laying it flat on some corner stands and then letting it sag, over a low heat, until it is slightly bowed the opposite way.
Thoughts and suggestions?
Thank you.
*When I ordered the windows they should have been steel reinforced extrusions but I only found out many years after that they weren't and should have been cheaper.
Thank you.
