Zippy
- Camborne, Cornwall
Hi - I am wondering if other folks overcompensate (like you do with conventional road bikes) when shifting to an easier gear? For example sifting from 7 to 6 (with a gripshift) I tend to click - and a bit - almost to 5 but not to actually click it in and then relax the gripshift to drop the chain onto 6 from a little beyond.
The reason I ask this is that I am fettling my 7 speed gripshift gears at the moment and I find, in order to have the cable tight enough to shift up (easier gear) it ends up so tight that on shifting down (towards harder gear) the chain is slow to switch sprockets.
If I slacken the cable the chain will drop down nicely but then I find I have to overcompensate to get the chain to climb again.
There doesnt seem to be an even balance.
Some things I may try - new cable sleeves (the cables are not brand new but well settled and oiled), new derraileur, new gripshifts - in that order.
The indexing at Hi and Lo ends are ok (in my opinion).
Any suggestions?
Any suggestions?
