The nearside is not for overtaking/filtering.
Which is why they put cycle lanes there
Yes, this applies to any vehicle, not just motor vehicles.
MUST NOT means there is a specific law prohibiting it, DO NOT and SHOULD NOT are advisory (though courts are likely to assign blame on the basis of compliance or otherwise).
It is straight forward, although worded to confuse.
2) No vehicle can overtake the vehicle closest to the crossing when that vehicle has stopped to allow someone to use the crossing.
Is the fact that it hasn't been tested therefore make the law non-existent?
With the exception to enter a designated ASL area??
Where the crossing is linked to a set of traffic lights, yes.I've never seen an ASL at a pedestrian crossing. Do they exist?
I don't think i've even seen one which is just at a pelican crossing.Where the crossing is linked to a set of traffic lights, yes.
Which is where you get zig zag lines... which the resent conversation is about..
I think it's fine if you are careful, as it seems you were since even this idiot didn't manage to hit you. Remember HC rule 163 says: "If the queue on your right is moving more slowly than you are, you may pass on the left". This indicates the difference between filtering on the left and overtaking on the left.I know I shouldn't filter on the inside but we sometimes take chances that we shouldn't.
Look slightly further back and then you will see the mentioning of zig zag linesI thought we where talking about the law in general when it came to filtering past stationary traffic, the law quoted from the highway code does not mention zigzag lines only the fact it is a pedestrian crossing.
Not that it matters,just being pedantic thats all![]()
I've had a brief look and can't see anything which specifies that the regulations referred to apply to motor vehicles only - do you have a direct link?The Highway Code is necessarily a simplification of the law anyway which is why the MUST rules are referenced with which law in particular it refers to so you can check the chapter and verse for the detail.
Which ones are you referring to?I've had a brief look and can't see anything which specifies that the regulations referred to apply to motor vehicles only - do you have a direct link?
To my knowledge there is nothing written in law regarding overtaking a vehicle by a junction.Overtaking past a junction
