painting crank arms
Cyclist33
Warrington
I would like to get my white crank arms painted in black or whatever. Gunmetal grey.
What will I need, and how do I do it?
Is it going to be cheaper than paying the paint shop the quoted 20 quid?
Thanks
Stu
snorri
If a professional paint shop will do the complete job, labour and materials for £20 go for it.
If you want cheap, I suppose you could get an aerosol spray and a newspaper to mask the rest of your bike for less than £10, but the quality is likely to be short lived.
Cyclist33
Cyclist33
Warrington
Ye
Yeah that's what I thought, altho I should note the crank arms are already removed from the bike so that would require much less Newspaper lop.
Assuming that you're going to be the current surface keyed, appropriate primer applied and then paint and clear coat for £20 then it's a bargain so go for it.
Aerosol sprays are good enough if you prepare the surface and then paint the parts in the correct manner (hanging them up, maintaining the correct temperature, applying an even coat, etc.). Parts required: degreaser, wet and dry, paint, clear-coat, tack cloths. You will probably get it done for £10/15 if you need everything or so so you're not saving much if anything.
Deleted member 23692
Power coating would be a much better option for crank arms. It's far harder wearing than paint
Trull
Aberdeenshire
That twenty quid is well spent with the paint shop. I'm assuming this is for powder coating? Just make sure you blank off any exposed threads maybe with a broken pedal etc.
Cyclist33
Cyclist33
Warrington
Get a pro to do it, by the time you get the primer colour and clearcoat it will cost more than that in paint
Yeah cheers that's how it seems! If I were going all out for frames etc but just for a pair of crank arms it ain't worth it. Unless anyone's got a fsa omega Chainset in black going spare..?!
midlife
The finishers should have the correct silicone bungs to block off the threads and tapers :smile:
Shaun
screenman
Using single pack it will rub off very quickly. The good thing is you should have plenty of paint left to repaint it after every few rides.
Hacienda71
Poundland. Primer and black paint sold there. You could even stick them in the oven for a few hours at very low to bake the paint. If it all goes tits up you can always strip it off with a bit of paint stripper. £2 worth a punt.
compo
Harlow
I have used those Poundland primers and black gloss and surprisingly they have done a good job on a number of small jobs such as quill stems, handlebars and seat posts on various old bikes. I don't think I would attempt a frame respray though.
Cyclist33
Cyclist33
Warrington
Cheers I'll give that a go if I get into it by way of a hobby!
Meanwhile, 20 quid well spent I feel..!
