Pearson Hanzo Fixed
Sorry for second post - please remove the first one!
On offer here is my 19" medium-sized Pearson Hanzo with the following specification:
Miche track hubs on open pro rims
Front tektro dual pivot brake. (Rear brake is not fitted, can be supplied).
48t x 16t fixed gear
Mudguards (reflector snapped off the rear)
Butted chromoly 19" frame - this is the medium size, somewhere near 54cm equivalent.
ITM Racer handlebars
Kona 110 mm stem
Kona aluminium seatpost
Vittoria 700c x 23mm tyres of some description.
I was knocked off the bike late last year and although the bloke from the bike shop near work said he would still ride it, I would change the handlebars and the brake levers (one of them got mangled). Otherwise the bike is unscathed - my elbow broke it's fall!
The bike has a few marks and scrapes from the rigours of commuting. It's still on it's original drive train which I can only guesstimate as covering 3-4k.  Complete with SPD pedals, I had it weighing in at approx 9.6kg.
I would rather not post. Can possibly deliver in the north west or take on a reasonably priced return train journey.
I'm looking for £300 ovno.
Damaged brake lever
Mudguard reflector snapped off
There are a few marks on that top tube
Miche hubs
Open Pro rims (free dirt under mudguards for that 'well used' look)
E
ed_o_brain
Anyone want to make an offer before this goes up on the bay tomorrow?
E
ed_o_brain
I've sold the wheels and already have people with dibs on the saddle on chainset.
The frame, seatbox, bottom bracket, forks and stem are still up for grabs.
marko49
Sounds good to me...so just to check, you would be including the following :
Specification:
Frame: Reynolds 520 tig weld
Fork: Steel precision tig weld
Headset: 1 1/8 cups and bearing
Sti/brake levers: Cane Creek
Brakes: Tektro long drop
Bottom bracket: FSA sealed
Seatpost: Alloy micro adjust
Handlebars: o/size alloy
Stem: o/size alloy
I am based in Sherborne, Dorset
marko
E
ed_o_brain
I think you are confusing my modified hanzo with the current version.
See the specification posted in the OP.
You are welcome to the handlebars, but I personally wouldn't re-use them.
You are welcome to the brake levers, but you can see in the pictures the left one is damaged.
I've no idea who manufactures the bottom bracket.
The seat post and stem are Kona items.
