I was commuting in this morning when after accelerating away from a set of lights I suddenly felt the right hand pedal felt a little odd, so I pulled over.
The right hand SPD was half out of the crank and pointing down at around a 30 degree angle, so clearly the pedal had been pulled out of the crank. I removed the pedal and looked at the threads, and on the outside of the crank they were worn and the pedal had the tell tale slivers of alloy embedded in the threads indicating they've been stripped. Given that I was about 4 or so miles from either work or a station, and 8 miles from home I made the decision to quickly get the pedal back in and get going as otherwise I was going to be significantly late and with a meeting this morning I couldn't really miss.
I am certain that when I fitted the pedal it was secured and absolutely certain that it was threaded correctly, the threads on the crankarm were already greased so I didn't add anymore, and I didn't over-tighten the threads, there was no play.
I now have a twofold issue, firstly, should I continue to cycle on the cranks? I did 4 subsequent miles after tightening, and the pedal hasn't moved, but I'm not sure what the state of the threads are, and am not inclined to undo the pedal.
Secondly, what likely recourse do I have with Tredz (retailer) or Felt regarding the cranks? Is this a warranty-able fix or am I likely to have to stump up for replacement cranks?
