Thank you.That being a hollowtech will be a 9/16th in my experience I have only encountered half inch on BMX bikes
And, thank you.Sheldon. Yours will be 9/16"
Thread Sizes
- Most pedals have 9/16" x 20 tpi threads.
- Pedals for one-piece cranks are 1/2" x 20 tpi.
- http://www.sheldonbrown.com/gloss_n-o.html#opc
Yep, thanks. I worked that out quite a while ago.Just in case you don't know this already, one pedal has a left hand thread. Best to work out which one before you bollock it up ridiculously tight in a forlorn attempt to undo it.
My mnemonic for that is 'The right pedal is right, the left pedal is wrong'! (Most bottom bracket threads are the opposite so 'Right is NOT right, and left is NOT wrong')Just in case you don't know this already, one pedal has a left hand thread. Best to work out which one before you bollock it up ridiculously tight in a forlorn attempt to undo it.
Very important. Unless you fancy having to blow torch them out in future.Yep, thanks. I worked that out quite a while ago.
Also best to use a spot of lube when fitting the new ones to save them locking up.
Tiny bit of Copaslip or similar copper lube. A little goes a long way!Yep, thanks. I worked that out quite a while ago.
