Alex321
- South Wales
Have you ever watched 'Shed and Buried'? They frequently have to deal with seized 2-strokes.
Yes, but that is when they have been unearthed after years, not one winter of 3-4 months.
If you get to the end of the season and you’ve not used up all your mixed fuel, what do you do with it? Can you put leftover mixed fuel in your car tank? If not, how do you dispose of it?
Fuel does have shelf life. So just enough in a can of petrol with oil added for the right ratio for the year. If there is some left, that's fine as it will small portion when the new petrol is added in the following year. I only add enough oil for additional new petrol to retain the same ratio.If you get to the end of the season and you’ve not used up all your mixed fuel, what do you do with it? Can you put leftover mixed fuel in your car tank? If not, how do you dispose of it?
Don't - the 2-stroke oil in the mix won't burn properly. It may even damage the catalytic converter.
It's still enough to contaminate the lambda sensor (etc). I wouldn't risk it for the sake of a few pounds.
The issue is not one of cost, but instead how to dispose of mixed fuel which is past its shelf life. Clearly the best solution is not to end up with unused fuel in the first place, but what do you do if you miss calculate?
If you have a four stroke petrol lawnmower, the old two stroke fuel can be used in it. I tend to run a weak two stroke mix through my mowers (big Stihl orchard mowers) at the start of the season to help lubricate the upper cylinders. Don’t overuse it and check plugs for any fouling.The issue is not one of cost, but instead how to dispose of mixed fuel which is past its shelf life. Clearly the best solution is not to end up with unused fuel in the first place, but what do you do if you miss calculate?
I've only got a litre left over so I'll have a small bonfire on Bonfire night as I've got some wood to burn.
That's not a good idea. Petrol can vapourise and explode.
https://www.bbc.co.uk/news/uk-england-kent-37279642
