biggs682
Smile a mile bike provider
- Northamptonshire
Freshly built Peugeot retro racing bike converted to single speed ideal as a cheap ride around or leave at station bike . Carbolite 23 1/2" or 59cm sized frame measured from centre of crank to centre of seat pinch bolt 23" or 58cm along the top tube ctc and has a standover height of 33 " or 84 cm .
Stronglight single 48 tooth front cog with a 15 tooth on the rear , fr wheel is a new Mavic cxp22 rim laced on to a parallex hub whilst rear is a used shimano rs500 unit both fitted with worn continental tyres .
weinmann 600 side pull calipers operated by shimano aero levers mounted on a chromed steel set of drops and a 95mm alloy quill stem .
Sr laprade semi fluted alloy micro adjust seat post PLEASE NOTE SADDLE IN PICTURES IS NOT INCLUDE BUT A SADDLE WILL BE INCLUDED .
PLEASE NOTE CRANK ARMS ARE NOT A MATCHING PAIR BUT OPERATE FINE AS THEY ARE .
please note bike is used and has loads of age related patina
rides nice and nimble ideal commuter
asking £105 collected from NN8 Wellingborough postcode
