AFrightfulHobgoblin
- Scotland
Hi - long time lurker etc... now looking for some advice.
I was out for a ride at the weekend when I started getting a click from the crank area - one faint click per rotation - got rapidly worse to a click-click-click that could be heard several metres away from the bike.
Investigated once I got home and I can see and feel a problem with the drive side crank bearings, I can see that the seal is slightly lifted, there are some rust marks at the same spot and it has a decidedly 'notchy' feel if I rotate it by hand. So far so good, but what do I do about it?
Bike manuals (it's a Focus) say that the PF30 (FSA) should be considered a permanent attachment once it's on a carbon frame. Some Google results suggest that maybe it can be removed with heat and force.
On the other hand, assuming I leave it attached to the frame I haven't found any good info about removing and replacing the bearings within the PF30 cups either.
So - do I aim to replace the whole PF30 assembly or just the bearings?
Thanks for any help.
(And what am I doing to cranks? First thing to wrong with my other bike was that the crank axle developed a fracture.)
