- London
How do you round the metal?Even if you put caps on, round the metal for safety.
top suggestion.
I recently acquired a lidl gas powered heatgun and heatshrink bits so am always on the look-out for innocent uses of it.
and am I the only one dazzled by SKS's variants in fixing systems? - my garage has a stack of their old mudguards ready to be plundered for bits.
Two posts up from that - black ones. Ordered.If you don't mind green - 10 for £2 on eBay: https://www.ebay.co.uk/itm/1-10-1-8...al-Pipe-Tube-Caps-Hat-x-10-Green/362001840212
Search for 'aerial cap' rather than 'mudguard cap'
thanks - though i wondered how you came to s earch aerial cap - i ddn't even know such a thing existed for aerials@Blue Hills - I searched 'aerial cap'. A 'rubber cap' search pulled up 100 shorter ones for £2.69 in black: https://www.ebay.co.uk/itm/20-100Pc...ew-Thread-Pipe-Post-Rubber-Cover/124199142221
yes i have a pair I'm concerned about - I think it's down to my very slight misfitting though - putting stress on the guard at the top where it's attached to the stay. Not a job to be rushed. The good news is that repairs with duct tape can last years.I have built up a mountain of SKS mudguard bits, it's almost as if they break habitually 😐. The last time I fitted a replacement set of SKS bluemels I fitted some nylon and rubber washers (not supplied by SKS) in an attempt to reduce stress and shock damage to the guards, so far so good but it's only been two years since the last refit..
After cutting you usually have some sharp burr left at the tip. In a crash this can rip your legs open. Hold with pliers and apply a file to the sharp bits. This is the disadvantage of leatherman style multitools, your pliers and file are connected.How do you round the metal?
thanks - though i wondered how you came to s earch aerial cap - i ddn't even know such a thing existed for aerials![]()
IF you have one.A dremel tool can do it more rapidly.
lidl and aldi fairly often do their own cheaper versions.IF you have one.
The dremel cutting disk is really good for brake and gear cable outers.lidl and aldi fairly often do their own cheaper versions.
Dremels, or the copies, are very handy things for various odd jobs, though for years I couldn't see the point of them.
Apart from being seriously bemused by the advertising genius who decided that Alexei Sayle was just the guy to promote them.
ah, thanks - does this avoid the problem you often get with cutters - having to tease the hole open on the end?The dremel cutting disk is really good for brake and gear cable outers.
