Pond Filters..........any recommendations (need new one urgently)
Dave7
Cheshire
I have a 6500 Ltr Bermuda filter which has just "died" on me. Cannot get the new parts it needs.
TBH........this one has been a real pain in the a*** when it comes to cleaning.............there must be much better makes/systems out there.
I have a separate internal pump with an external filter.
As I say, it has to be 6500 Ltr or more and I want EASY CLEAN.
Any suggestions appreciated.
Thanks
Dave7
Dave7
Cheshire
[QUOTE 5086399, member: 45"]If you want easy clean, then you want a pump in the pond and an external filter tank.[/QUOTE]
I will edit the post........thanks.
I do have a pond pump and an external filter which has "died"
Cuchilo
Prize winning member X2
London
Not sure how an external filter can die . Just fill it with different filtration products . Keep the old stuff wet and add some of that to the new stuff as all the good stuff is living in there .
If you want a new filter then just buy a filter with separate compartments and draining points .
Dave7
Dave7
Cheshire
Two problems that need new parts which I cant get as filter is obsolete.
