dan_bo
How much does it cost to Oldham?
Hope and so forth- are they worth it? Do they last 4 times longer than the shimano jobs as the price exttapolation may suggest or are they just bling?
yebbut would a Hope stainless job outlast a Shimano one? You'd bloody hope so....Just bling. I've used both Hope and Shimano extensively.
The good thing about Hope BB's though is that you can change the bearings where you can't with Shimano.
However... you would have to buy a Hope BB tool which cost's more then a new Shimano BB
My memory is shakey on this, but pretty sure I've changed the bearings on a Hope BB without a tool. You can knock them out with hammer + screwdriver, and use a headset press to put the new ones back on. Okay, that is a tool. I imagine of the bodges for getting headset cups in would work on the bearings.
You wanna try two ultegra jobs over 11 cyclocross races last season....The current xt version I have on my hybrid appears to be a goodun' but this may be due to previous units being badly installed (from the factory I might add!). To be honest now I have got the BB70 item Lasting more than 2k (I think this current one must have done at least 6k) I don't think I would bother trying an expensive alternative. When they were failing every 1.8-2k I might have paid anything!
Ok cheers.No it doesn't.
Bit of threaded bar, some nuts and appropriate washers. Ghettotastic.If you had a headset press of course..not many people do
