Presta/Schraeder conversion
Andy_R
Hard of hearing..I said Herd of Herring..oh FFS..
County Durham
I'd also better check I've screwed the thingies in right way up too
Calling @Fnaar ..........Yup, check your flange is the right way up
GrasB
Nr Cambridge
Converting from the wide Schraeder to the smaller Presta is easier and require no technical skill at all
Mavic do "Shims" that seat the valve
You can also get other "sleeves"
These work by supporting the valve joint in a double walled rims and should be used to reduce strain in that area due to stem & tube movement.
Alternatively just buy Schwalbe Presta tubes as their "retaining nut" already has a flange that will seat it in a Shhraeder hole
These are the best method for shallow box & single walled rims. It's also something I'd strongly recommend for use with deeper double walled rims.
