Easy way to deal with that - move chain to biggest cog, then change down WITHOUT rotating the pedals - hey presto, nice slack cable to work with.HaloJ said:They'll likely be pretty tight especially as you'll be increasing the cable tension when you rotate them anti-clockwise.
PatrickPending said:Shall I take it its an aluminium frame? Theese often leave the shops ungreased and then you get galvanic corrosion between the adjuster and the frame - the adjuster won't budge! This is what happened to my Allez - nothing would shift them. Not much of a problem really you can adjust the rear mech using the adjuster on that, but adjusting the front will be a bit more tricky.
AlanW said:Pull up and then twist.
