Probably the Best 1x Groupset You'll Ever See - Dura Ace Di2 w/ Powermeter & CeramicSpeed
ryan_w
London
I've jumped on to the SRAM 12 speed bandwagon hence you lucky bunch have the opportunity to buy this lot.
This has been put together without cutting any corners and no expense spared:
  • Dura Ace R9100-P power meter (£1,300)
  • WolfTooth 44T chainring (£85)
  • CeramicSpeed Coated PF30 Shimano bottom bracket (£300 - 24mm spindle and serviced today)
  • Dura Ace 9170R Di2 shifters (£600 w/ brake calipers)
  • Ultegra RX R805 clutch rear derailleur (£260) with Ceramic Speed pulley wheels (almost brand new - £180)
  • 3T Overdrive 9-32T cassette (two rides old, cost £230). Comes with DT Swiss XDR freehub already fitted (£70)
  • Dura Ace 9170R brake calipers and pads (off a 58cm frame and kept hoses as long as possible)
  • Dura Ace 9170R 160/140 discs (£110)
  • Dura Ace 9100 chain (£30)
  • Shimano Di2 BT-DN110 battery (£90)
  • Shimano Di2 EW-WU111 bluetooth module (£75)
  • Shimano Di2 EW-RS910 barend junction port (£85)
  • Shimano Di2 SM-JC41 junction box (£20)
  • All Shimano Di2 wires needed for install (£100)
That's £3,535 worth of groupset (ouch)...
There are some small cosmetic marks on the shifters, mech, BB and crank arms, but it works 100% and no expense has been spared with this build.
I have professionally cleaned and serviced all parts (I have my own workshop) and this is a complete setup and ready to be installed. All you would need are two brake olives and barbs (I may have some) and bleed the system once installed.
I want £1,000 for the lot, ideally collected from Fulham due to value.
I don't need to sell since have another bike I could use it on, so no stupid offers. It's cheap enough as is and the best you can buy.
Cheers,
Ryan
Nerv
Lurker from LFGSS here so freshly registered and can't PM, wondering if you'd split the group and brakeset away from the power meter, BB and chainset?
