Globalti
The idea here is to pre-heat the water entering the main house cylinder, which is heated by the gas boiler. A 20 tube panel (£350) fed by a small 12v DC pump (£28) and a 12v differential controller (£95) supplies a 160 litre cylinder (£125 unused off Eblag) which is plumbed in tandem with the main house cylinder below. The weight of the cylinder bears on the studwork around the airing cupboard, which is directly below. The panel is directly above the cylinder with around 20m of 10mm copper tube taking the liquid, which is water with car anti-freeze. There is only about 25 litres of liquid in the tank and system.
Set up was pretty easy, the hardest part was getting the frame for the tubes onto the roof and I realise now that I made it difficult for myself by trying to slip the SS straps through the tiles; I should have just pushed up the tiles at the four corners and punched cleanly through the felt. The tiles are concave underneath so it was simple to grind away channels for the 10mm pipes to pass under the lower edges. All pipework is sloped uphill so the system bleeds itself pretty well as it fills and the radiator bleed cap on the manifold has turned out to be unnecessary so I will remove it in the Spring.
Even on a freezing December day with snow on the tubes, they are picking up solar radiation and the pump is kicking in for a few minutes at a time. When we see how it performs this summer, we will consider adding a second panel. If we end up with excess heat the differential controller has a function that powers a motorised valve via a relay and once the top cylinder is up to 60 C it can divert the flow downstairs using the house cylinder as a heat dump. We plan to have a bigger, faster reheat, twin coil house cylinder installed in February.
We asked Ribble Valley BC if Building Regs approval was needed and they didn't know so they came anyway, the inspector took one look outside and said "Fine, I'll send the approval next week".
Pics here: Can you see them? http://s36.photobucket.com/albums/e49/C957/Solar project 2011/?albumview=slideshow
