Psychopath?
Hacienda71
Where do you fall on the spectrum.
I will kick off with 39%
Though your conscience is in the right place you also have a pragmatic streak and generally aren’t afraid to do your own dirty work! You’re no shrinking violet - but no daredevil either. You generally have little trouble seeing things from another person’s perspective but, at the same time, are no pushover. ‘Everything in moderation – including moderation’ might sum up your approach to life.
ColinJ
Puzzle game procrastinator!
6%!
You are warm and empathic with a heightened awareness of social responsibility and a strong sense of conscience. You like to carefully weigh up the pros and cons of a situation before you act and are generally averse to taking risks. You are very much a ‘people person’ and dislike conflict. ‘Do unto others…’ are your watchwords. But, although you avoid hurting others, those residing at the higher end of the psychopathic spectrum might not be as considerate, so stay vigilant to avoid being hurt unnecessarily.
Ha ha - no wonder I never made it in this dog-has-eaten-the-other-dogs-and-now-started-eating-the-cats world! :laugh:
classic33
Leg End Member
Your score 67%
You can play hardball with the best of them! You know what you want and are not afraid to go for it – even if it means bending the rules occasionally and putting a few noses out of joint on the way. Nothing fazes you. You are decisive, self-confident and pretty much up for anything. You are a ‘means-to-an-end’ person. For you, it’s not necessarily a matter of right or wrong, but of what gets the job done. ‘Bring it on’ is your mantra, but to help those around you keep their heads, you should learn some tricks to help you temper your self-satisfying tendencies...
swee'pea99
30%. The summary seems spookily in line with my perception of myself too..
"You are warm and empathic with a heightened awareness of social responsibility and a strong sense of conscience. You like to carefully weigh up the pros and cons of a situation before you act and are generally averse to taking risks. You are very much a ‘people person’ and dislike conflict. ‘Do unto others…’ are your watchwords."
(Glad there were no questions about how many people you've killed mind...)
Mad Doug Biker
Mediocrity Manifest.
Craggy Island
Can someone post the link with the actual address please??
39%. Not bad!
Hill Wimp
Fair weathered,fair minded but easily persuaded.
18% with the same comments
classic33
Leg End Member
The questions that they said didn't matter were actually part of the test. Such as which type of animal, you're age, sex.
