I don't like much of anything from Halfords
Don't see why not.
Cheap stuff like inner tubes, lube, oils and repair kits all work fine. And if they are cheaper then other places then they get my money.
The solution goes on to the tube, after being roughened with sandpaper so it will key in. When tacky, the patch is put on to the glue, foil side down (foil removed first, of course!). The patch is pressured on with the fingers and finally stretch out so as to split the paper, which is removed in pieces FROM THE MIDDLE so as not to lift the edges of the patch.
Made the schoolboy error of gluing the patch wrong side down, then wondering why it was completely flat again 100 metres up the road! That was after the replacement tube also punctured!
And another thing while I'm moaning, patches don't work too well when the hole is right by the seam on the tube, which I also found out by biter experience![]()
Is there a reason not to leave the backing film on there?
i let the glue set and then soak the back off with waterthis is what I do, too -- getting the backing off is just too fiddly.
