Putting more air into my fork - how?
wiggydiggy
Treated myself to a Genesis Mantle 20 and after a spin out on it I need to put some more air in the fork as I'm a bigger chap, and found the forks a little soft and bottomed out a couple times - the valve on the bottom looks like a good place to start.
Its a RockShox XC32 TK 29" Solo Air, and the RS site lists this as an adjustment:Solo Air: Spring Adjust: Air pressure via a single Schrader valve
Is it as simple as connecting my pump (have a JoeBlow Sport) and pumping, or do I need a special high pressure pump?
Cheers.
You need a fork pump. And it's on the top, unscrew the plastic cover.
wiggydiggy
wiggydiggy
