Queensferry crossing.
twentysix by twentyfive
Clinging on tightly
Over the Hill
The deck at either end of the gaps are at different heights. Think some spoke fettling is called for..........
Mad Doug Biker
Banned from every bar in the Galaxy
Craggy Island
Personally, I think the old bridge should be made into part of a cycle and pedestrian (it should be big enough to sensibly segregate) path (if one doesn't already exist). Lets have our own bridge instead of being all snivelling and complaining that we can't use 'their' bridge.:whistle: :okay:
Besides, you will be able to get great shots of trains going over THE Forth Bridge, so what is not to like?? :giggle:
rualexander
So if no provision has been made for a cycling/pedestrian lane on the new bridge, what happens in ten or twenty years if/when the existing bridge becomes unmaintainable either due to physical deterioration or cost and they decide to demolish it?
Brandane
Miles cannot be done unless moving!
Ayrshire.
The old (current) FRB has great cycle facilities in the form of a fully segregated and wide path in both directions. It is shared with pedestrians, but there is plenty of space for both.
Goggs
Good question :ohmy:
DaveReading
Don't suffer fools gladly (must try harder!)
Reading, obvs
By that time, we'll probably have it to ourselves. Assuming the bridge isn't about to collapse under its own weight, adding that of a few hundred cyclists at any given time is unlikely to break the camel's back.
And if it does - hey, we're expendable. :rolleyes:
Joey Shabadoo
My pronouns are "He", "Him" and "buggerlugs"
Given the way the gaps between road sections on the old bridge are going, we'll probably need mountain bikes to get across
Mr Celine
Discordian
It's a bit unnerving on first use due to the barriers looking rather low from the vantage point of a bicycle.
Goggs
So bad that when our modified car club headed South for shows we'd always go via Stirling.
