rh100
I wondered if someone could advise on the quick release lever on the hub of the front wheel.
the wheel took a knock when it was off the bike for (another) inner tube repair. The lever on the quick release bolts came away from the mechanism and so then did the cap that the lever goes through.
What had happened was that the small circlip that holds the lever through the cap had come away.
I found and closed up the circlip as much as possible with a pair of pliers and reassembled the quick release mechanism. The wheel is now fitted back on the bike and seems to be ok. Is the circlip there solely to hold the lever to the mechanism when the mechanism has been released, and am I right thinking that when the lever is closed to tighten mechanism the pressure of the mechanism holding together will prevent the lever from coming away? Just don't fancy having the wheel come off at any point.
Thanks
Rich
Thanks
Rich
		 didn't inspire me with confidence
