Amanda P
- York. Well, York-ish...
Here's a list of what's left:
Stems:
Kalloy front-loading stem, ~125mm forward extension. Polished alloy; lettering a little worn.
Steel MTB stem in red oxide primer, ~110mm forward extension. No pinch bolts but any bolts of about M5 would do. Has hole to act as stop for front canti brake cable. Finish in your choice of enamel or powder coat!
Black steel MTB stem. ~75mm forward extension.
Black steel Marin MTB stem, ~110mm forward extension. Has cable stop and pulley for front canti brake cable. Finish absolutely knackered, but functional! From my 80s Marin Palisades Trail.
Brake levers:
Shimano Exage aero. Black rubber hoods. Rather marked, and one bit of grey plastic trim is cracked – doesn’t affect action and is almost invisible in use. Quick release button.
Bars:
80s generic Maes pattern, no name. 37cm overall.
Let me know where to send 'em, I'll send 'em, and then you can send me the postage cost plus any extra you care to include.
The clutter in the background of the photos may give you a clue as to why I'm wanting rid of these!
Stems:
Brake levers:
Bars:
