a.twiddler
Rans Seat Mesh
I’ve been using the Rans Stratus XP a lot over the past year and had noticed some threads pulling loose on the seat mesh a while ago. It needed seeing to to prevent it worsening and I mentioned it to Mrs T. She’s been altering some curtains this weekend so she said she’d do it while she had the sewing machine out.
Removal
Removing the mesh from the seat frame without taking the frame off the bike was easy enough. The main tensioning straps across the back are held with velcro then once loosened they needed to be pulled through the buckles and fully separated. I’d initially thought they’d just need loosening and could just be pulled upwards. The frame has horizontal bars which curve behind the seat which stop this being possible.
There are also a couple of small vertical straps which go round the lowest bar just to keep you on your toes.
The frame was quite dusty once the mesh was off, but after a wipe over showed no sign of corrosion or wear and tear.
Mrs T did a thorough repair job, attending not only to the affected stitching but the full height and across the top.
Re fitting
It took about 10 minutes to get the mesh off but about 40 to get it back on and re tensioned. It might take another couple of goes to get the tensioning straps back to where they were but the resulting job looks good to my eye. A pity that I didn’t take a “before” picture.
Awaiting a test ride now!
Removal
Re fitting
