nickyboy
Norven Mankey
- You want hills? We got hills
So I got a nice bike a couple of years ago; Btwin 720. Came with full Campagnolo Centaur kit. Looked great and I was looking forward to riding it hard in the Peak District
Fast forward a couple of years and about 9,000 miles. It's cost me a fortune in replacement bits
2 replacement cassettes
3 chains (I've changed to KMC as Campagnolo chains are ridiculously expensive)
Rear derailleur (spring tension had all but gone)
Left shifter (plastic surround broke)
Right shifter is about to go
Rear brake caliper is about to go
That lot is about £500 plus labour to fit
LBS reckons that Centaur just isn't up to the job and I should run it into the ground and replace with Shimano which, for the equivalent, is much cheaper
For the record, I clean and lube the bike every week. The miles I do are hard miles with plenty of climbing but I would have expected expensive components like Centaur to last longer. Other than the front brake, front mech and chainrings, everything is replaced by 9,000 miles
..(well i could but refuse to, if its functional, thats good enough for me)
