It would require a dynamo with windings to give a higher voltage 36/48 Volts. Dynamo are usually 6 Volts. This increased voltage requires a larger dynamo due to extra windings of copper. Now the current requirement to actually charge a ebike battery. To,gain any real benefit you would need more than 1 Ampere, again increasing copper winding thickness. Rotation of the wheel is also a factor in producing the required Voltage and current. Maybe if you could get several thousand RPM of the wheel, but it's more in the range of hundreds of revolutions per minute, not sufficient.The solar panel doing the recharging I wonder if it's any good and will most ebikes follow suit ,I once asked in a bike shop why can't a dynamo charge the battery when you are riding never got a satisfactory answer does anyone here know.
Have a look at Barnabe Chaillot's you tube channel - link to one of his vids above - and see his solar-powered trailer-mounted charger! Mind you, the conditions where he is, are rather different to the conditions we find here in Britain.As far as a solar recharge - the size of the panel needed to provide any worthwhile level of charging would be far too big to put on a bike - even on a trailer!
Yes with today's tec why can't it be done.Confused, you mean an ebike having a dynamo that charges its own battery?
It's been explained above.Yes with today's tec why can't it be done.
I would have thought with all the clever tec today they would have come up with something.Its called 'perpetual motion', and is against the laws of thermodynamics.
To recharge itself, while expending significant energy moving rider and bicycle, and with all the inefficiencies and losses, is impossible. At best the energy recuperated would be negligible, nowhere near enough to rechqrge a battery.
Its like usimg your own house lights to energise your solar panels to power your lights...it just ain't happening.
They did it's called a "long lead"I would have thought with all the clever tec today they would have come up with something.
😄They did it's called a "long lead"
F1 cars have something that stores energy up in the braking think it's called DRM something like that maybe?Mr Scott above sums up the problem perfectly. Even the cleverest engineer cannot chamge the laws of physics.
