Recommend an ODBII Reader
Following on from the catalyst issues, can anyone recommend a good ODBII reader that will do things like airbags/abs and maybe more ?.
I 'had' two - a basic plug in one that works with an app over bluetooth - useful for finding out codes and less than £30.
And an Autel ML629 (about £100) that did the reading and various resets for ABS/airbag etc - came in very handy with diagnosing some airbag issues, finding faulty crankshaft sensor and highlighting a failed coil pack when it eventually threw a code. Unfortunately, 'someone' related to me, broke it and never replaced it (you know the old saying about never lending stuff out...)
Ideally needs to do Nissan vehicles and a Vauxhall/Stellantis van, and maybe go a little deeper as the van has way more complex stuff in it that could need checking one day.
What do you recommend ?
Seevio
South Glos
If you have a laptop, a USB obd2 scanner can be had for under a tenner and then it's just a case of getting the appropriate software for your vehicle.
Drago
Icarsoft v2.0 or 3.0. Pricy, but superb.
Carista. Inexpensive, but an annual sub is £60. On the upside this means its always up to date, and theres a free 30 day trial period that gives full functionality. It also can be used to set configuration, such as DRLs, radio logos, all sorts of weird stuff. I keep mine in the van for emergencies.
