Recommend me a...
GrumpyGregry
Here for rides.
... "be seen" front light.
It needs to be
small
unobtrusive when turned off
waterproof
rechargeable (ideally)
and must fit on the bike's head tube NOT the handlebars.
My phart one went awol at some point this week.
lejogger
Wirral
Darn it... was going to suggest the Knog blinder, but that will only go on the bars... depending on the width of your head tube.
Wobblers
Euthermic
Minkowski Space
If having a bracket that will fit to the brake bolt counts as fitting to the bike's head tube, B+M's Ixon IQ might fit the bill. Reasonably bright, good battery life (4-5 hours on Eneloops) and facility for recharging batteries if you buy the optional plug-in adaptor. The downsides are that it's somewhat fragile (I killed mine after dropping it) and the battery contacts and hinges for the battery compartment aren't very robust.
Otherwise, get another couple of Pharts (stop giggling at the back there!)? After all, it's not like they're expensive...
Andrew_P
In between here and there
It's a great lamp. t's a see by and fits on handlebars. Please read the spec ;)
whoops I did read most of it..
