Recycling Powerlinks
I am Spartacus
N Staffs
Who is for recycling powerlinks?
I have spares in my little box of bits, but I like to take chain off as and when to clean thoroughly.. this time tho' I must have clicked it into place well and truly good and it refuses to unhinge.... oh well.. unless
someone knows a trick with a pair of pointy pliers?
I know it says dont re use on the 'tin' but times are 'ard
Squeeze it together first, then push the link open
I am Spartacus
I am Spartacus
N Staffs
Next time I want chain off, I'll pop the rivet off... it wont budge,
Tried a bit of heat
Its a nasty hg73 chain anyways, I'll ditch as soon as a sideplate cracks, as they usually do
Dan B
Disengaged member
I've never had problems reusing them.
Yes, some are stiffer than others. Get a pair of pliers and squeeze them "diagonally", so that each jaw is pushing on only one face. If that makes any sense
Steve Austin
The Marmalade Kid
Mlehworld
This needs to be on everyones Xmas List
http://www.chainreactioncycles.com/Models.aspx?PartnerID=79&ModelID=46600
I am Spartacus
I am Spartacus
N Staffs
Lost patience with it... popped the link out and put a connex one in which I know I can undo even with numb cold fingers at roadside.. even tho the damn thing doesnt like going round 11 sprockets
eeek 9.99 for pliers....?
Jonathan M
Merseyside
+1, used them to the point of failiure with one powerlink going through several changes of chain.
If I can't get one to undo by hand I usually give the link a good scrub with a toothbrush to remove as much grit as possible, and then a blast with GT85 or somesuch. Never had to resort to using pliars of any type to do the job. If it won't release then walk away, make a brew, don't get cheesed off with it as any job just gets worse if I get frustrated with it.
