gaz
Cycle Camera TV
- South Croydon
Got a slow p during the day. So tyre was flat as a pancake when I got to it. Right so I got It off, replaced the tube and pumped away. Hissssss! Had a look and one side of the tyre by the valve had popped off the rim :s
whip it off and replace it again. Before pumping I check and again the tyre won't sit over that part of the valve, it looks like the tube might be blocking it. So I pump the tyre up a litle and wiggle it into place. Pump it up. A few mins later hissssss. And he tyre is off the rim in the same place. WTF?
Any ideas on what is causing this and how to fix it?
