Removal of security screws ?
cyberknight
I have these on my shed door hinges but it looks like the wood has swollen/ settled and i can hardly open the door, i have already sanded the door down a bit but it is still very tight so does anyone know where i can get a clutch head screwdriver?
When i try ebay / google all i get is American adverts
Deleted member 23692
There are these, but they ain't cheap!! - http://www.securitysafetyproducts.c...ews-fixings/clutch-head-removal-tool-rt41.php Make use you get the right size toll for the screws you have.
Do you have a dremel to hand? If so,try grinding faces on the ramps do a normal screwdriver will get some purchase
slowmotion
Quite dreadful
lost somewhere
Use a small stud extractor?
Rohloff_Brompton_Rider
Formerly just_fixed
FIL has a set of them, not sure if they fit but i can ask.
Depends on whether they're stainless or not. If they're stainless then you'll have no option but to either buy, beg, borrow or steal a tungsten bladed tool to grip the head or like recommended above dremmel/grind the heads flat and put in a slot.
02GF74
I am not convinced the screwfix and similar security bit sets will help - they are for doing up that tuype of screw with the sloping slots ... actually I cannot see howyou can undo them unless there is some sort of special sochet that bites into thesides of the head. ..... after all the whole point is to make them effing hard to undo!
