I need to replace the cranks on my bike as the left one has stripped the pedal threads but the actual pedal is fine. I dont know how , i bought it used everything else on it was spot on but didnt spot it when i bought the bike as it was wedged on. Struggling to find a suitable set of cranks in my budget. I have a diamondback heist 2 with a 1x setup and 175mm crank arms. It is none boost. I was going to reuse the chainring but cant find just a set of cranks that are 175mm that are not square taper or out of budget. I can get a shimano deore m617 crankset cheap, can i just take the rings off and put mine single one on there?
Or should i get a set of square taper arms and a new BB for the same price? If i do this i see that the UN55(is that the right one) comes in different lengths how do i determine which one is correct for my bike to match chain line ect? I know about the shell width but not about the spindle length as its got an external BB fitted at moment.
