MontyVeda
- Lancaster... the little city.
A friend has a rotten threshold and was asking my advice on repairing it (in other words, asking me to do it)...
That's an image I found online which is illustrative enough. (in fact the page it comes from looks like a good guide)
The frames down to the threshold are still sound so won't need much fettling... just a case of knocking out all the rotten wood down to the brick work and replacing it.
I started to have a harebrained idea that instead of wood, forming a concrete threshold instead, which would be more hard wearing in the long run... but that presents the problem of damp permeating up through the concrete and into the wooden frame. Then i started thinking about putting a barrier down first, either plastic (damp proof course) or bitumen maybe, and forming the concrete threshold on top.
Of course i could do it the normal way, with wood... but would it need to be hardwood or will a treated soft wood do?
One problem my friend has is, when it rains hard, a fast flowing stream develops and runs past the door, which is probably why the previous threshold has gone rotten in less than a decade.
Plastic is a consideration but finding something prefabricated that fits perfectly* might be hard, and plastic mightn't be up to all the foot traffic over the years.
*Wooden shims could make it fit, but then the occasional stream will make those eventually turn to mush.
So, any advice from our cycling builders and joiners?
