Replacing brake blocks
gaz
Cycle Camera TV
South Croydon
Using the type that slide out, i've undone the screw that holds them in place, but they won't slide out ;)
Any ideas what i can do?
Campag jobbies? They fit pretty firmly. I used hot water screwdriver to lever the first few millimetres then added more welly.
gaz
gaz
Cycle Camera TV
South Croydon
Shimano..
I'll give it another go.. i think i may have to release some cable tension to get a better angle at it.
swee'pea99
Shimano?
What you can do is throw them away and get yourself some of these. Much better in the dry, incomparably better in the wet. (They're usually about £7 a pair too, so these are a real bargain.)
buddha
I've the same brakes.
As they had worn quite a bit there wasn't enough block left to push out with a screwdriver. In the end I removed one by screwing a wood screw into the (rear-facing) end and pulling on the screw with mole grips. The other wouldn't come out that way so I had to, carefully, drill out the remaining block. Twas a pig of a job!
gaz
gaz
Cycle Camera TV
South Croydon
Did it, had to remove the whole brake block, and then i was able to slide out the rubber pad. Not enough frame clearence to do it without removing the whole block.
swee'pea99
Excellent. Well done. Now chuck 'em out & get yourself some Aztecs. ;)
alecstilleyedye
nothing in moderation
take the little bolt out too. they are there for numpties who don't put the pad in correctly, and when they corrode in place and the hex head strips, mean you have to bin the whole holder.
this advice came from a decent lbs run by a racing pro.
Tynan
e4
no screw? blimey, never occured to me, makes sense
and peple change the pads on the bike?
I've just done with the cartridge types after getting the hump with wearing a set down in not more than a month (rims were a bit buggered), swtiched over to a chunkier one piece sort, still brand name, ultegra I think, working just fine
gaz
gaz
Cycle Camera TV
South Croydon
Got a link? i can see this set wearing down quickly as well if the weather continues.
HaloJ
Rabid cycle nut
Watford
I've headed the other way on my commuter. Removed the blocks and replaced them with cartridge types. I was burning through blocks and thought I'd give the swisstop cartridges a go. My to work commute is mainly down hill and in heavy traffic so plenty of braking to avoid the crazies.
Kestevan
Last of the Summer Winos
Holmfirth.
Take the cassette out of the brake and hold it in place in a vice.
Use a small flat head screwdriver and a hammer to drift the block out of the cassette.
Replace with Kool stop pads, and re-install in the caliper.
Jobs a good-un :angry:
thanos
for a road bike with dual pivot brakes, ive seen the recommendations for kool stops (i assume my link is correct). however im a bit perplexed on the cartridge 'holder' bit. Do i need something as pricey as this?
or are aztecs good enough?
