T4tomo
Ah cheers, its a long time since I bought mine. Bar prefixes I was fine with but the suffixes I was struggling with.No, L is light as without rack, etc! Titanium bits classify it as X while R is with rack, etc. M,S, H or P relate to the type of bars fitted.
That makes mine an S3X then.
My personal view is the rack is unecessary weight. If i ever needed to carrry more than my messenger bag with me then the front pannier system is the way to go, which is a very straight forward retro fit and almost no extra weight if not being used.
If you are getting 6 gears you should be Ok without the "extra" low gearing. I have the higher range of 3 gears (54 chainring 13 sprocket) on my "3" which is fine for my commute. standard gearing is 50 chainring plus you get an additional lower range with the 16 sprocket on the back, without going down to the 44 chainring.
