Rocker Plate
Venod
Eh up
Yorkshire
I have just built a Rocker Plate for use with the Turbo, it gives a more realistic feel to riding indoors.
Does any body else use one ? there are various designs out there mostly home made, a few are available for purchase, there is a FaceBook group.
https://www.facebook.com/groups/415329188897706/
This is mine.
I like Skol
A Minging Manc...
Surely that's where rollers come in? I obviously mean balance and movement as I know you can't lean on the rollers (or not for long anyway :B))
Just one thing I might change at first glance is to sit the bearings next to each other in pairs at either end of the shaft. Can't see the point of placing that much bending force on the shaft unnecessarily.
Venod
Venod
Eh up
Yorkshire
Yes rollers are good for balance and movement, but you can't program them like the trainer to simulate real life riding. (unless you have some of the expensive ones)
The inner bearings are placed there (in line with the trainer feet) to give support to the platform, the shaft is 20mm, I would be surprised if I bent it.
Marchaugh
I was thinking of making one just like that for my tacx neo. How did you hold the inner tubes in place? Or did you not need to?
What are the holes for? I'm guessing that 4 are for the neo feet and the other two for the inner tube valves.
How did you secure your neo in place? Did the holes do the job?
Venod
Venod
Eh up
Yorkshire
The holes for the feet were OK but the only hole saw I had was bigger than the Neo feet, and you could move it slightly in the holes, I have since added some aluminium channel that I had in the shed, this is cut so it fits between the feet, one piece at front another at rear, it is now held solid, I have heard of somebody using up turned cups screwed to the top plate to accommodate the feet.
Venod
Venod
Eh up
Yorkshire
The inner tubes are not secured at all the pressure in them is enough to hold them in position.
The hole at the center of the tubes allows for inflation and air relief during compression.
Marchaugh
Thanks, going to make mine tomorrow
nutsaboutbikes
This is mine.
View attachment 401295 View attachment 401296 View attachment 401297
Good job on the rocker plate. How do you find riding on it, does it feel more natural than being fixed in place?
Venod
Venod
Eh up
Yorkshire
I have a Tacx Neo which has a slight movement built in, but the rocker plates gives a lot more, it does feel more natural and gives your bum a bit of relief, you can adjust the pressure to suite, I like a soft ride, I also fitted an old bearing under the front mount so the steering swivels.
One of the tubes has just developed an hole, I have patched it for now, it seems to have perished at the joint.
As a replacement I have ordered these, https://www.amazon.co.uk/gp/product/B074CVB7NF?ref_=pe_3187911_185740111_TE_item&pldnSite=1
I was thinking of trying balls, but I like the ease of adjustability these should provide.
CXRAndy
Lincs
I made these out of 10mm ply, using hole saw s
Neo is firmly held in place with opposing fixtures
Marchaugh
Just completed mine. I used casters as the rotation in the middle to start with until my bearings came.
