Plenty in IlkleyHilly?
Do you need/want a cafe stop?
Yes. I will probably suggest a route that way tomorrow evening if I have time.Plenty in Ilkley
I have assumed that a hilly route is required ... The area is VERY hilly so unless you just go up and down the Aire valley you are going to encounter a lot of hills - embrace them!
Here is a strenuous, scenic 34 miler, largely on quiet roads. I prefer it in an anti-clockwise direction.
Map:
Profile:
GPX route file attached.
As for cafes ... if you are doing this in the evening the cafes will probably be closed!
@arranandy - if you like that one, I'll do one out towards Ilkley for you.
I'm staying at the Bankfield Mercure Hotel
Well, I hope you are not out on those hills in the massive thunderstorm which has just hit the area!Thanks Colin.
Maybe do that one tomorrow evening. I'm staying at the Bankfield Mercure Hotel just on the edge of Bingley
Well, I hope you are not out on those hills in the massive thunderstorm which has just hit the area!![]()
I'm glad that you managed to find shelter. Better luck tomorrow!Tell me about it. Planned ride cut short as the thunderstorm started as I was heading towards Silsden. Ended up sheltering in a bus stop. Hopefully the weather will be better tomorrow evening
