Rubbing Sound
jowwy
Not here offten enough to argue
I have new giant defy 4 - two weeks old
but i have switched out the 32hole giant wheels for my shimano r500's, but underload, especially while seated on short, sharp hills when trying to put the power down i here a rubbing sound on the drive side
what could be causing this problem??
i weigh 220lbs, but i have had these wheels on my raliegh sprint for 12months with no problems, but the raliegh does have a clearance for larger tyres (28mm).
Could it be that the wheels are flexing underload and rubbing on the brake blocks??
Thanks
defy-one
could be
J
jowwy
its only happening in the lowest two gears and when i need to put the power down on really sharp climbs
i have a climb which i have to do virtually from a standing start as its a tight go back on yourself hairpin bend, when i drop to the 2nd lowest gear and put in a hard grind it rubs, later on in the climb when i'm spinning it dissappears
gbb
Peterborough
R500s are known to be flexy...when i first got mine, if i gave it beans out of the saddle on a hill, you'd hear the wheel magnet hit the sensor as the wheel flexed.
Gary E
Hampshire
disconnect the rear brake (temporarily) and try the hill again (open up the quick release on the brake or just remove the brake pads). That way you can eliminate/confirm your idea.
J
jowwy
i'm going to run the giant s-r2 rear wheel with 32h rim and see what happens then, if no rubbing then i'll keep them wheels on the bike and put the r500's on the turbo trainer instead
