Rumble stips on cycle path in Hyde Park
Letter to Boris
I am SO annoyed by these new rumble strips and today, i got a puncture as a direct result of going over them. They are the most blatant anti-cycling measure i've ever seen. I'll happily sign any letter arguing against them. In fact, i'm going to write to Boris! - as a fellow cyclist he must have some sympathy!!
Kaid
Leicester
I understand the need for some sort of pavement / cycle path markings for partially sighted pedestrians but this can be achieved through the dimple designed pavements.
We have the rumble strips in Leicester. A simple solution is to have the strips at a right angle to the flow of traffic but instead they have put them in parallel.
Bman
Herts.
Can anyone post a picture of these rumble strips? I'm pretty sure I know what you mean from the descriptions. But I may be completely wrong.
L
LOGAN 5
This is the reply from the Royal Parks re the humps. I suggested having cobbles over the whole width at least we could ride over them more safely than the enormous humps. Cyclists are riding into the ped side to avoid them. Another one has sprouted on the section opposite Kensington Park approaching the bridge from the Rotten Row end.
Thank you for your email and thank you for your patience in awaiting a reply while we carried out necessary investigations.
This project is being managed for us by an outside Engineering Consultancy. We became aware of some problems with the type and quality of sett laying as soon as the contractors opened up the work to the public. The issues are largely to do with quality of implementation and not design or original specification. Consequently we have asked for a Site Engineer’s report, upon receipt of which we can look to making improvements or reworking.
The works are ongoing and additional surfacing works carried out recently will mitigate some problems being experienced by cyclists. We have also asked the contractors to add some extra warning signage during the construction period.
Notwithstanding these issues, the cycle lane improvements were designed by Highway Engineers following a stage 1 & 2 Safety Audit of the route. The Royal Park Cycle Group which includes representatives of LCC (London Cycle Campaign) , CTC (Cycle Touring Club), Sustrans and the Met Police were consulted on the designs, as were Park Management.
The setts have been laid at junctions and to delineate where the pathway changes from segregated pedestrian and cyclist use to shared-use areas. New markings and asphalt surfaces are also part of this scheme to mark out the shared use/ crossing areas.
The setts themselves are a tactile aid to those unfamiliar with white line markings and vulnerable pedestrian users such as the visually impaired, elderly and very young, many of whom struggle to perceive the cycle route.
The use of granite setts to delineate junctions and changes in use is a standard detail that has been used successfully elsewhere in Hyde Park and in other Royal Parks including Regent’s and Greenwich.
Thank you again for your email. I hope this response has gone some way to resolving your concerns.
BentMikey
Rider of Seolferwulf
South London
I took a picture at the weekend of the worst one near HPC, and more tar has been applied to make it considerably milder. I'd be content if they're all made like that one.
Origamist
I received a similar reply. We'll have to see what it's like when the correct design is implemented.
The cyclist calming measures in Clapham Common are the sensory sort; I imagine the HP design will be more like the setts in Clapham, but perhaps with a bit more vertical deflection and/or in closer proximity if they want to slow cyclists.
L
LOGAN 5
Last week they had flattened some of the humps on the cycle side now all that remains are cobbles on the ped side! Don't know if they're planning to reinstall some other style speed bump.
gaz
Cycle Camera TV
South Croydon
The ones going through clapham common are good. i just wish they would clean the leaves more often!
