Having recently made the decision to get back into cycling properly, I have subsequently purchased a Giant SCR 4 which I am extremely pleased with, apart from one thing.
Having messed around with the gears to find out whats what I don't seem to be able to change up and down through the gears. The flick buds that I have are more than adequate for my needs, they just only seem to go in one way, not allowing me to move up and down the gears as I would have expected.
A rather embarrassing beginners issue/question but if anyone can point a novice in the right direction I would be extremely grateful!
) one way to put on more tension. This does the indexing, so change gear with a lever and put some tension on the rear mech cable with that turn nut untill it changes gear. Put a bit on, then lift the back wheel up and pedal abit. When it changes up, change down one gear, you might have to take abit of tension off.
modified SCR4 as my winterbike, and am very pleased with the, er ...frame
