SdD Card Problems
fossyant Ride It Like You Stole It! Location South Manchester 14 Mar 2016 #2 You should have 12 months guarantee, especially on a San Disk - do you know where you bought it ? Can you format it on the PC then try it in the camera ?
fossyant Ride It Like You Stole It! Location South Manchester 14 Mar 2016 #3 Sounds odd. I've had one SD card fail for an unknown reason.
Fnaar Smutmaster General Location Thumberland 14 Mar 2016 #4 I had a similar failure once, but after cleaning the card's contacts, it was fine again.
accountantpete OAP 14 Mar 2016 #5 Check whether it is genuine View: https://www.youtube.com/watch?v=n-oDewYj6ic
Tanis8472 Guru Location Boston. The UK for avoidance of doubt. 14 Mar 2016 #6 Download this tool and use option-format full and format adjustment size. Make SURE you select the correct drive https://www.sdcard.org/downloads/formatter_4/
G growingvegetables Guru Location Leeds 14 Mar 2016 #7 Tanis8472 said: Download this tool and use option-format full and format adjustment size. Make SURE you select the correct drive https://www.sdcard.org/downloads/formatter_4/ Click to expand... THIS! Not the SD formatter I use - but a formatter specific to SD cards has brought several back to life.
